hooking up power windows and locks
anyone know a good DIY for hooking up power windows and locks to a fully manual civic ?
i got the stuff from a junked 99-00EX, and want to wire it into my 98DX.
is this a plug and play operation or difficult ?
Re: hooking up power windows and locks (iwhichisme)
Locks are easy. Windows are not so easy. You should pull power windows from a car that had them instead of rigging in some power window kit. It will only leave you disappointed with the sporadic results it will give.
Jon Black
Jon Black
yay for already having all that installed hehehe
another free bump cause even though I don't need it would be interesting to know
Re: hooking up power windows and locks (UtahRockabilly)
i did pull the windows from a car, 99-00EX, and wanna put it in a 98DX, i got the glass, controls, harnesses from each door, the mechanical stuff, everything but the harness that runs in the dash, connecting the 2 doors.
Re: hooking up power windows and locks (brak)
quick question... alittle ot, can you install keyless entry into a car with manual locks.
im not sure about the window install but free bump for you.
edit: im pretty sure the wires all are there on a car that is all manual so the power window/lock install will probibly be plug and play.
[Modified by euclid, 9:58 PM 3/1/2003]
Re: hooking up power windows and locks (euclid)
quick question... alittle ot, can you install keyless entry into a car with manual locks?
Jon Black]
Whoa... ok. Let me clear up all the confusion on this matter as I'm in the middle of this install in my 99 EK. I got basically everything out of a pair of 00 Si doors (power window regulators, door lock solenoids, wiring harnesses). That's pretty much all you need to get your doors ready for it. The only problem is that the door harnesses have no where to plug into as they exit the doors. Any 96-00 civic that didn't come with power windows doesn't have the correct harness behind the dash for the door harnesses to plug into.
I went and pulled the entire dash harness from another wrecked 2000 Si at a local junkyard, including fuse box and pretty much everything for $125. That thing is huge and it was a bitch to pull, and I expect it to be even more difficult to install in my EK (replacing my current non-power window harness).
If you want to ghetto rig it, I'm sure it's possible but don't hook things directly up to power, 'cause you're supposed to use relays so as not to burn the window regulator motors out.
My way will give you OEM functionality and general freshness and cleanness for power windows, locks, mirrors, and tweets.
Good luck!
msg YUMVtec He's the one who did the above! If you need any more info, and I can help you out some to the best of my knowledge. For wiring diagrams, GET YOUR HELMS!
[Modified by Cuong-nutz, 8:52 PM 3/1/2003]
Good luck!
o, alrighty
if i get all the harnesses, is it easy to connect it all ?
Good luck
Re: hooking up power windows and locks (Cuong-nutz)
Thanks
Jon Black
[Modified by Jon Black, 7:20 PM 3/1/2003]
urkuletz
Honda Civic (2001 - 2005)
12-14-2007 05:47 AM
civiceg94
07-10-2007 12:27 PM
