b16a2 vs b16a3
b16a2 vs b16a3
the previous owner of my em1 replaced the b16a2 with a b16a3. he put some kind of aftermarket im on it. will it still have the same power? it doesn't seem to have the power it should.
Re: b16a2 vs b16a3
B16A2='99-'00|Civic Si (EM)-USDM-160hp@7600-111tq@7000
B16A3='93-'94|del Sol VTEC-USDM-160hp@7600-111tq@7000
Only difference to my knowledge is that they either converted your car to OBD1 or they simply changed the bottom block and kept the old head
Crazy Honda Guy
Re: b16a2 vs b16a3
Same engine pretty much.....
all second gen B16A's had the P30 intake manifold on it, it is a kiss *** design and makes more power than most aftermarket models
Re: b16a2 vs b16a3
They also had the Obd2 B16A3 in the 96-97 Del Sol Vtec. But more that likely its just converted to OBD1.
Re: b16a2 vs b16a3
from what he told me, he swapped the dist. nd injectors over to obd2. i don't know what intake manifold it is. I do know it has a p2T ecu. i had to bypass the cfk..it has a greddy header on it, would 3" exhaust help?
Re: b16a2 vs b16a3
it should have bout the same power except there could be other things.. some motors come gifted and some motors come bad..it sounds like i think you need a dyno run to c where its power is and then dyno tune it again after a few more upgrades to c how much better u do..oh yea bigger piping will help out pretty good.. better air flow but remember, you need back pressure to so be sure to put a muffler on..
Crazy Honda Guy
Re: b16a2 vs b16a3
It's the ecu that actually dictates the obd, but doesn't really play much of a role in 2nd gen B16 engines themselves
Crazy Honda Guy
Re: b16a2 vs b16a3
You are right. I was almost positive there was when i was researching these a few years ago. But after researching again.... there isn't one. Except for one website that i believe is unreliable. Thanks for the correction.
Re: b16a2 vs b16a3
from what i know the b16a3 had a longer gear ratio tranny like the GSR's.
there 2nd was longer than most b16 trannys.
correct me if im wrong.
auburnBoy
19
05-10-2006 01:10 AM
civic2slo
01-05-2005 06:12 AM
