b16a2 itr pistons
Old 01-15-2010, 08:29 AM
scooterbuilteh2's Avatar
Default b16a2 itr pistons
ok i want to kno if anyone has had any problems with itr pistons in a b16a2
Old 01-15-2010, 08:37 AM
90Rexx's Avatar
Default Re: b16a2 itr pistons
there should be any problem both b16 and b18 bore is 81mm stock....
what issue are you having?
Old 01-15-2010, 08:39 AM
a friend of mine is saying its going to change the stroke and im pretty sure hes wrong. or am i?
Old 01-15-2010, 08:45 AM
THC07's Avatar
pistons change stroke? wow, maybe i should find a new profession
Old 01-15-2010, 08:46 AM
Crazy Honda Guy
Deetz's Avatar
B16 pistons have higher compression
Old 01-15-2010, 08:50 AM
b16a2 pistons are going to have higher compression the b18c5 pistons?
Old 01-15-2010, 09:03 AM
JDM Tiger's Avatar
rods and crank changes stroke not pistons
Old 01-15-2010, 09:06 AM
ya thats what i told him and he read different on a different forum and didnt believe me. but compression b16a2 more than b18c5?
Old 01-15-2010, 09:27 AM
CivicSpoon's Avatar
Yes, the ITR pistons will lower your compression slightly. The USDM ones will lower it quite a bit, but the JDM ones will only lower it so much that it won't be noticeable. You'd be better off with JDM B16A pistons, but that would only be a slight compression raise.
Old 01-15-2010, 11:04 AM
thumper64's Avatar
Do the ITR pistons and turbo it!
Old 01-15-2010, 11:13 AM
THC07's Avatar
http://www.zealautowerks.com/bseries.html
have fun
blackeg
21
01-04-2012 04:16 PM
o0o_tylor_o0o
02-27-2009 08:40 PM
stonet149
12
11-02-2008 09:29 PM
8000+
03-14-2004 07:48 AM
jetdriven
05-06-2002 06:44 AM
Quick Reply: b16a2 itr pistons
