B16a2 into a 98 LX What else do I Need??
Hey guys just put a bone stock b16 into a 98 LX 4Dr. I used the engine harness from the B16 along with the ECU. It starts up and runs but not very good, I know i might need a conversion harness or something of that sort, any help will be much appriciated
Thanx guys trying to get this kids swap runing nice
Re: B16a2 into a 98 LX What else do I Need??
was the b16 obd1 or obd2 because the car is obd2 and if the motor isnt then you need a conversion harness. also by the intake manifold there are 3 sensors that have the same harness plug and they can be easily mixed up so i would retrace them with a wire diagram and make sure they are hooked up to the right sensors
The car is obd2, i used the B16 engine harness and computer but there's a missing plug that needs to go in to the b16 ecu. the plug comes off the interior harness from the 99-00 si's but on the 96-98 civic its straight from the engine harness so i'm not sure if i need a jumper or use a different ecu
h22_crx
08-10-2007 10:10 PM
Capt. Jimbo McSubipants
03-19-2005 11:36 AM
Tokyo_X-treme_Racer
03-10-2005 10:40 AM
