j series trannys???
Old 05-12-2011, 04:45 AM
projectEGhatch's Avatar
Icon2 j series trannys???
i want to do a j32 swap in my eg hatch. i found a j32a1 for 500. i was wondering what manual transmissions will work with the j32? i know there is a 6 speed but is there any others? maby any 5 speeds? i thought some accords came with a 5 speed j series.
Old 05-12-2011, 04:59 AM
Crashtestdummy's Avatar
Default Re: j series trannys???
http://www.hondatuningmagazine.com/t...ited_slip.html
Looks like there are only two 6 speed trannys, doesn't seem to have a 5speed that will bolt up to it. I hope your great with wiring tho cause i beleive those are throttle by wire.
Old 05-12-2011, 08:32 AM
hondamark35's Avatar
you're right to say the wiring won't be easy, though i've heard rumours that there is now a swap harness available. however the J32A1 is not throttle-by-wire. i think the A3 is when that started.
Old 05-13-2011, 04:49 AM
i found a company that makes the harness for 450.
also what do you have to do for shift linkages for the accord 6speed to fit in my eg hatch?
and what would i do about an ecu?
Old 02-06-2018, 11:12 AM
Klkids's Avatar
Hey I have a 2000 acura tl wanna do a manual transmission, which transmission bolted on yours easily or the easier one
Old 02-06-2018, 05:42 PM
Freedo_Civegra's Avatar
Didn't realize this thread was from FREAKING TWO THOUSAND ELEVEN! Lol
purplerain11
07-03-2012 12:51 AM
lango-H22
12-18-2010 07:41 AM
ZCboost
08-20-2004 05:55 AM
Quick Reply: j series trannys???
