Wiring for a JDM B16A(2) going into EG hatch....
Old 08-18-2004, 08:51 AM
ZCboost's Avatar
Default Wiring for a JDM B16A(2) going into EG hatch....
I searched but didn't come up with anything that I thought would help. I'm posting this for my little brother who is dropping a 92-95 JDM B16A SiR2(hydro tranny) engine into his 95 hatch. I've done a JDM swap, so I know the wiring is reversed. When I did my swap I went D series to D series, so I just used my stock CX harness and wired the VTEC separately. Can he do that? I don't think I've ever heard of someone using a D series wiring harness on a B16A. If it's possible then that's awesome, but is he better off getting a B series harness? He has his B series axles now and his comptech intake arrived yesterday, so we're pretty much ready to go.
ZCboost is offline
Old 08-18-2004, 09:00 AM
handa's Avatar
Default Re: Wiring for a JDM B16A(2) going into EG hatch.... (ZCboost)
you can use D-series wiring harness on your swap. I know some of them are not wired for vtec, therefore you'll have to run those lines (knock sensor, vtec solenoid, etc.) separately straight to the ecu. i personally use an obd1 wiring harness off a b-series.
D-series wired for vtec: EX, SI....CX??
someone add more to this.....
handa is offline
Old 08-19-2004, 07:45 PM
93eg27's Avatar
im in the middle of this same issue. i have a b16a jdm motor and have a 93 cx hatch. after plenty of people telling me to rig this and rig that. im spent going to bone yard after bone yard i finnally found the vtec solinoid, knock sensor etc. plugs and now im ready to extend my o2 censor and i should be rockin.
so after my long shpeel. i will say it is possible to use your d-series harness. but it would be a whole lot easier to go with the b-series one. IMO.
good luck let me know how it goes
93eg27 is offline
Old 08-20-2004, 05:17 AM
B16EJ's Avatar
Default Re: Wiring for a JDM B16A(2) going into EG hatch.... (93eg27)
Why do you have to extend your 02 sensor? with my swap (b16a3 delsol motor into 94 civic si, cdn ex) all i had to do was wire in my knock sensor wire and that was it. is it different on hatchbacks? the o2 sensor on the b16 was perfect length, even after i got a itr header for it fit without issues. IMO a d series with vtec harness would be just the same, if i'm not mistaken only the b16a3 came with a knock sensor and it took me 5 min to wire it in. easy as hell
B16EJ is offline
Old 08-20-2004, 05:35 AM
jbscivichb92's Avatar
i just did this swap. use your stock harness. since you have a cx you have to run the vtec wires, knock sensor, and O2 sensor wires. the cx comes with a 1 wire O2 and the sirII comes with a 4 wire. just do a search for the wiring diagram. other than that everything else just bolts right in.
jbscivichb92 is offline
Old 08-20-2004, 05:55 AM
hatchdrvr's Avatar
Default Re: Wiring for a JDM B16A(2) going into EG hatch.... (jbscivichb92)
I used my stock DX wirting harness and added the neccesary wires. This should help....
http://tech.hybridgarage.com/tech/index.html
hatchdrvr is offline
Mtntech
K Series
02-25-2014 01:16 PM
flipldls
10-27-2009 11:51 PM
slumpedeg
08-30-2009 03:11 PM
msinsky14
03-27-2006 05:53 PM
Quick Reply: Wiring for a JDM B16A(2) going into EG hatch....
  • Ask a Question
Question Title:
Description:
