B16a swap questions
B16a swap questions
So I have a b16a in a 94 eg.
An I'm getting code 14,19,12.
I know code 19 is cause the ecu is auto an mine it's manual.
Code 14 is the iacv. I clean it already few times an it still has a high idle an when I disconnect it the idle gets normal.
Can I used d15b7 iacv on my b16a?
The Grumpiest
Re: B16a swap questions
Get the correct ECU for your car. I can't believe you are going to try and diagnose any other problems with the wrong "brain" running the car. If you are still throwing a code after the ECU replacement only THEN should you worry about it.
Okay. So I guess my p30 is bad cause I try a p28 with chrome chip tuned for a b16a with type r top end. It was my old motor an got to barrow The ecu.
An I got NO cel. But when I jump the wires to check i there's any codes the srs blinks.
