b16a swap JDM 1st gen
if i wanna convert the 1st gen b16a into obd1 with a hydro tranny is that possible i just want to double check. To my knowledge i need an obd1 dizzy ecu and a hydro tranny correct? if im wrong please LMK thanks ;]
Re: b16a swap JDM 1st gen (rysingsun86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rysingsun86 »</TD></TR><TR><TD CLASS="quote">if i wanna convert the 1st gen b16a into obd1 with a hydro tranny is that possible i just want to double check. To my knowledge i need an obd1 dizzy ecu and a hydro tranny correct? if im wrong please LMK thanks ;]</TD></TR></TABLE>
all you need is the tranny, dizzy, injectors and a obd-1 wire harness..
when i blew the motor in my del sol vtec i replaced it with a gen 1 motor to save some money.. my obd-1 b16a went right on to the motor.
i used my old injectors and distubtor..
the vtec solenoid plug was different.. i just poped the pin out my the plug on my harness and put the obd-0 plug on it..
also the fan switch is different.. i used the thermostat housing off my old motor and carryed the obd-1 switch over..
mynameizstitch
01-26-2010 06:11 AM
Nameless Warrior
12-12-2006 10:30 AM
