b16a shakez
b16a shakez
I got a question.
When i start my car, The car sometimes shake like crazy and when i try driving it, it would lag and sound like a bucket. could it be the ignition coil? or something to do with the distributor? My oil is fine, My spark plug wire is fine also, and i replace the Spark plug too. But i can't figure out the problem. its shake every once and awhile and would sometimes goes away. Is there any kind of electrical wire that would cause that also?
Re: b16a shakez (bunske123)
what do you mean "sounds like a bucket" the last time i tried listening to a bucket...well....i didn't hear anything, turns out inanimate objects don't make much noise.
in any case, is your timing alright? make sure you didn't skip a tooth or something, that would cause the car to be slow and have a rough idle. does it always bog or is it only sometimes under certain conditions?
Re: b16a shakez (forcefedferio)
well it just boggs like crazy when im on low gear. like first gear an' second gear unless it in high rpm it dont lagg as much. but it feel like something making my motor slow
markH22eg6
12
04-12-2008 04:02 PM
PerfectTechs
03-23-2008 10:15 AM
Takumi Fujiwara
04-12-2005 03:03 PM
slowsleeper
09-03-2004 08:13 AM
