b16a runnig rich
b16a runnig rich
to start i have a jdm b16a obd1 in an ek
its runnig rich , before i get all the comments , it has a hondata with plx wideband, and i check the o2 sensor it is working properly. lambda 12.4, AFr around .80 trying to get to 14 using 15 ethonal
b16a just re ringed , crower stage 2 3/4 race cams, bigger intake and throttle body , jasma header high flow cat. stock injectors ( tried a different pair didn't make a differnece).
fpr set to 34 psi
i have tried everything i can think of not iacv, tps, no leaks in intake, timing is dead on , no jumped teeth on timing belt. dizzy been rebuild.
190lbs per cylindar , leakdown nill.
any ideas or thing i havn't looked at, if i do tuning alone i have to remove 30% of fuel from stock map, which is way to much
fpr set to 34 psi
