b16 swap problem!! Please halp
I am helping a freind do a b16 into his 93 hatch. Everything is done, but we came across a problem, it wont start. We checked the spark in each plug. we pulled the injectors and they are fine. If the motor is getting fuel and a spark, whgat could be wrong?? I noticed when turn the key over the exhaust manifold warms up slightly and I can hear a putt out of the muffler but not much. Could this have some thing to do with the timeing??
Thanks in advance. Any ideas are appreciated
[Modified by 90_Civic_Hatch, 9:57 AM 8/3/2002]
Re: b16 swap problem!! Please halp (90_Civic_Hatch)
first
is it a first or second gen b16
check your dist and make sure the wires are in the correct order
if you havent replaced the spark plugs, do it.
what ecu are you using
check your ignition timing too.
i agree with Homer there...ur distributer mite be either off or wires to it is wrong, and second ur ecu...and double check all ur wires
Re: b16 swap problem!! Please halp (dniedacess)
I have checked all the dist. wires they are fine. I have no idea about the ECU, so I'll go check that out when I get to his house this week. Anything else that would cause this problem????? Thanks
Oh, and it is a 2nd gen B16
[Modified by 90_Civic_Hatch, 8:03 PM 8/4/2002]
you checked the oil levels? i know those things come full of oil when you get them, maybe theres too much? idunno...
Re: b16 swap problem!! Please halp (R you serious)
Yes we checked all fluids, replaced all fluids. I thought the ignition timeing only can be done one way and there is no room for mistakes with that. How can I check this ???? Thanks
[Modified by 90_Civic_Hatch, 8:54 PM 8/6/2002]
this is actually my car.second gen B16 There is a vacum hose that was not connected. I have this little black think on the top of my dx motor that has a spot for a vacum line and an electrical clip to go on it. but I do not have this thing on my b16, so i do not have the clip connected nor the vacum line could this be my problem. could it be that my wiring is wrong all that i changed was added vtec solenoid, pressure switch, knock and vtec ground. If the wiring is bad, I thought just the vtec would not work. I need help I have a car that wont start its really depressing
Re: b16 swap problem!! Please halp (93dx--hatch)
i'm sorry iread, but i might have missed, did you say you GOT A SPARK? if not, your distributor might be good, but check the coil and there is also like an igniter chip inside the distributor check that
Re: b16 swap problem!! Please halp (kwik2nec)
I have spark and I have fuel. Are the plugs from the first gen b16 different from the second gen. I have spark and fuel could the timing be off? how do i check that? I did not change the timing belt.
StreetEG
10
07-25-2005 11:48 AM
