B16 EG cluster.
Old 03-21-2004, 10:02 AM
Chopper 2 Hopper
justBLZE's Avatar
Default B16 EG cluster.
My friend just bought a 92 Civic Si with B16 engine and the stock cluster is off on the RPMs.
Which cluster should we buy to get accurate readings?
Old 03-21-2004, 10:04 AM
compwc18's Avatar
Default Re: B16 EG cluster. (tommy69)
you should get a AutoMeter 5" Sport-Comp Tach... thats what I use, since I dont even have a tach on my cluster...
Old 03-21-2004, 10:05 AM
Chopper 2 Hopper
justBLZE's Avatar
Default Re: B16 EG cluster. (compwc18)
He actually has one of those tach's from the previous Civic he owned.
I was thinking that there might be a cluster that will work fine with the swapped engine.
Old 03-21-2004, 10:12 AM
compwc18's Avatar
well then why doesnt he do that... there was a guy here on HT that installed a GSR cluster into a EG awhile back... lookedgood but it takes way too much time...
Old 03-21-2004, 10:13 AM
Chopper 2 Hopper
justBLZE's Avatar
I guess he wanted to keep the clean look, without the monster tack in the middle
Wouldn't a JDM SIR cluster work?
Old 03-21-2004, 10:18 AM
92b16vx's Avatar
And how exactly do you know his cluster is off? Are you measuring it against a digital tach, or another caliberated tach?
Old 03-21-2004, 10:20 AM
compwc18's Avatar
Default Re: (92b16vx)
well mt tach isnt in the middle, i have it in the corner next to the door, it looks really good there :-D
Old 03-21-2004, 10:21 AM
Chopper 2 Hopper
justBLZE's Avatar
Idles at 1500 RPM and goes all the way to 9RPM when shifting with a stock B16A.
Then again while crusing 80 his tach is at 4000 RPM when I think it should be at 4400 unless he has different gear ratios.
Still gotta figure that out.
Old 03-21-2004, 10:23 AM
compwc18's Avatar
Default Re: (tommy69)
maybe hes revving the motor too high... b16's, you should shift around 8,000 thats where i shift... my revlimiter is at 8200 but im also running the obd1 p72 chipped ecu
Old 03-21-2004, 10:29 AM
Chopper 2 Hopper
justBLZE's Avatar
Default Re: (compwc18)
It's a B16A with LSD tranny (S4C on the cast) and the JDM P30 ECU.
Old 03-21-2004, 10:30 AM
92RED Hatch's Avatar
yeah dude...9 grand is way too high with a B16 with stock valvetrain. Plus there isn't any power up that high as well
Old 03-21-2004, 10:31 AM
compwc18's Avatar
Default Re: (92RED Hatch)
that is true.... id say use the auto meter tach, they are also pretty accurate :-D
Old 03-21-2004, 10:32 AM
compwc18's Avatar
also, if u just use the auto meter tach that he had before, then he could save that extra money for a sluter and get something for the motor
Chopper 2 Hopper
justBLZE's Avatar
I think the rev limiter is still at 8200 but since the tach is 500RPM too high it looks like we shift at 9K that's the whole point of that post.
Old 03-21-2004, 10:59 AM
Kevedge's Avatar
just go buy the sir cluster, passwordjdm has them for 170. its a nice cluster because the tach is for the motor, so the redline and everything is for the B16. plus it lights up amber
Old 03-21-2004, 11:05 AM
Chopper 2 Hopper
justBLZE's Avatar
Default Re: (Kevedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevedge &raquo;</TD></TR><TR><TD CLASS="quote">just go buy the sir cluster, passwordjdm has them for 170. its a nice cluster because the tach is for the motor, so the redline and everything is for the B16. plus it lights up amber </TD></TR></TABLE>
That's exectly what I told him to do, just wanted to make sure it will work fine with the B16 motor, thanks for your help.
Old 03-21-2004, 11:16 AM
Kevedge's Avatar
Yepp, it will work fine. Thats what me and a friend are running. Both have b16's. Plus the cluster plugs right in, no extra wiring needed. I think the only things that dont work is the srs light doesnt come on, but there are right ups on making it so you can have it turn on.
Old 03-21-2004, 12:18 PM
92b16vx's Avatar
My VX cluster worked perfectly with my B16A.
Supa Troopa
62
07-19-2023 10:07 AM
89DXDann
06-04-2004 11:38 PM
GDM Z28
02-01-2004 01:10 PM
Quick Reply: B16 EG cluster.
