b16 distributor question
Old 02-26-2006, 07:03 AM
s2000june's Avatar
Default b16 distributor question
ive got a b16a2 obd2 motor in my 92 cx. Its been in for about a year.. Im running a sohc vtec wiring harness that plugs up to the motor.. My dizzy is shot and the dizzy on the car is 2plug.. can i run a d16z6 distributor since there 2 plug or does it have to be a dohc 2plug dizzy only or obd1 i should say..
Old 02-26-2006, 07:07 AM
shiftgear8000's Avatar
Default Re: b16 distributor question (civicrida3)
has to be a b-series dizzy.......a single cam dizzy won't work. But depending what went bad on yours, you can take the internals from the d-series one and put it in the b-series housing.
Old 02-26-2006, 09:19 AM
s2000june's Avatar
Default Re: b16 distributor question (shiftgear8000)
yah i did that last week my ignition coil went on my b16 dist swapped it with a z6 now the rotor is broke. im having no luck thanks for the response
Old 02-26-2006, 09:58 AM
well you can't use a d16 rotor on a b-series anyways
Old 02-26-2006, 10:28 AM
s2000june's Avatar
yah... i figure that out when i took everything apart.. but the icm and igniton coil is compat. thanks man
jdmsi22
04-06-2009 11:35 AM
Damills
02-04-2007 10:59 PM
shrug
14
12-15-2006 03:51 PM
vtec2nr
03-03-2003 12:02 PM
Supahatch
06-22-2002 11:02 AM
Quick Reply: b16 distributor question
