B16 blocks
Re: B16 blocks
blocks should be the same, if u are asking because u want to swap blocks you will be fine. There may be a slight difference in compression due to pistons being usdm or jdm but i believe they are pretty much the same.
Re: B16 blocks
im trying to find another block so i can start a motor build and i found one for 50 bucks and its a b16a and i have a b16a2 in my si i was just wondering what the difference was if there was any at all
Re: B16 blocks
It will work for what you want to do. theyre pretty much the same as i stated earlier. Only difference would be the pistons and i believe the jdm motor doesnt have a knock sensor but someone will have to chime in cause im not sure.
Re: B16 blocks
im not to worried about the compression or pistons because im going to bore it out and sleeve it
Re: B16 blocks
lol they can say that all they want im not putting an ls block in my si..i want to keep the 16
phferreira1
16
06-28-2013 07:35 PM
I3ooS710
12-02-2005 08:09 AM
Rust
14
03-01-2003 01:48 PM
BLKCRX
06-01-2002 10:07 PM
