B-swap question, do I need new motor mounts?
Swaping a B16A2 into my 98 hatch (D16Y7), would I need new motor mounts to do this or the ones that come with the motor will line up?
I was looking in hasport site and they list their mounts fit both b-d series motors, so figured they'd be the same?
thanks
thanks
Re: (jeffnerette)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA »</TD></TR><TR><TD CLASS="quote">the engine is from an si correct? if so use the mounts that the si used. </TD></TR></TABLE>
thank you sir! yes its from si, so no need for $$ mounts, great!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffnerette »</TD></TR><TR><TD CLASS="quote">search button is your friend
https://honda-tech.com/zerothread/1998336
you're welcome</TD></TR></TABLE>
I read that before, there's no info about motor mounts there.
Re: B-swap question, do I need new motor mounts? (shake-zula)
you can also use any mounts off any acura integra Bseries it doesnt have to be SI junk yards will rape you for SI parts and 9 times out of 10 they will have more integras in the yard than SI's
Re: B-swap question, do I need new motor mounts? (duefuss)
It would have to be mounts from a 96-01 integra or a 99-00 SI, but I think you said you had mounts that came with the motor up there.
motor is still in buddy's car, he's doing k swap so it will come out of his car 2000 si and go in my car 98 dx, so I wouldn't need to buy anything else to make this work except whatever comes of his car, right? tranny, axels, mounts, linkages, ecu, etc.. I'm getting them all with the engine, is there anything else i'll need?
thanks
thanks
Re: (MrXclusivE)
Nope won't need anything else besides maybe a ecu, everything else would bolt up.. I don't know if the obd2a and ob2b plugs are the same though.
