b-series swap and axle issues
Old 12-28-2008, 05:01 PM
tacorunner87's Avatar
Default b-series swap and axle issues
sorry for the noob questions. im doing a b18b swap into my 94 hatch, it was also auto now its manual. so basicly i did auto to manual and dseries to bseries all in one swap. got the motor in which is a 95 and transmission which is an 01 axles im using are off a 93 from my previous crx that had a b18 in it. this is where im having issues. the passenger side went together perfect. inter. shaft went on fine, but the driver side axle is about 1.5-2" to short. i searched around.only thing i can figure is i need 2001 axles and intermediate shaft. or could it be that i need an automatic axle?
Old 12-28-2008, 05:11 PM
Inliner's Avatar
Default Re: b-series swap and axle issues
any drivers side DC axle should work.
Old 12-28-2008, 05:27 PM
Seagull Management
94EG8's Avatar
any B-series manual hydro axles and intermediate shaft, '90 - '93 integra manual axles, plus corresponding intermediate shaft should also work, otherwise i'd say you have some sort of engine placement issue.
Old 12-28-2008, 05:31 PM
engine dropped in perfect all three mounts lined up perfect no issues there.
Old 12-28-2008, 05:38 PM
Seagull Management
94EG8's Avatar
just out of curiosity did you use a conversion mount on the passenger's side or cut and weld on a manual pocket mount?
Old 12-28-2008, 07:29 PM
conversion mount
Old 12-29-2008, 07:21 AM
Seagull Management
94EG8's Avatar
conversion mount
Hmm, in that case i'd say you've either got the wrong axle and/or intermediate shaft.
Old 12-29-2008, 05:09 PM
i bought 95 axles today ill see if that fixes the issue tomorrow or wednesday
Old 12-30-2008, 02:53 PM
95 axle is what i needed
Monsta427
10-09-2014 04:37 AM
grant97teg
07-01-2009 09:10 AM
integrawow
04-26-2007 08:41 AM
idewson
03-02-2006 05:20 PM
allmotorlsvtecrx
02-19-2004 06:58 AM
Quick Reply: b-series swap and axle issues
