Axle Shaft replacement: Which brand?
Old 08-06-2007, 04:37 PM
tj2133's Avatar
Default Axle Shaft replacement: Which brand?
Car: 1995 Honda Civic Ex / Vtech / 5-speed / coupe
The passenger-side inboard joint boot is torn apart. About 4 years ago (40K miles ago) I had this same axle shaft replaced (Honda OEM part) because the outboard joint boot had torn apart and was causing a clicking sound when I made left-turns.
I know I have to replace the axle shaft again. Instead of getting a brand new OEM Honda part this time, I'm thinking of maybe an aftermarket axle shaft or a remanufactured Honda part. Does anyone have experience (good or bad) with the following brands? Or can anyone recommend a brand?
1) Brand new Honda OEM ($420)
2) Remanufactured Honda ($205)
3) A1 Cardone ($80)
4) Empi ($92)
5) Arc ($66)
6) CVU ($73)
Old 08-06-2007, 04:39 PM
* B A N N E D *
n1_egsex's Avatar
Default Re: Axle Shaft replacement: Which brand? (tj2133)
just get whatever you can, all same ****
Old 08-06-2007, 04:46 PM
t0p_sh0tta's Avatar
Default Re: Axle Shaft replacement: Which brand? (JJSpecTuning)
OEM axles are $273 @ HondaPartsDeals.com, but you can get one for $70 at your local parts store with a lifetime warranty.
Old 08-06-2007, 06:54 PM
zerovandez's Avatar
CARDONE
Old 08-06-2007, 07:05 PM
smileycvc's Avatar
Default Re: (zerovandez)
NAPA
Old 08-07-2007, 06:57 AM
tj2133's Avatar
So, among aftermarket brands is there any difference in quality? (Napa, Cardone, Empi, Arc, CVU)
Old 08-07-2007, 07:00 AM
speedooo's Avatar
advanced auto with the lifetime warranty, i paid about $60
Old 08-07-2007, 07:59 AM
1995Civic's Avatar
Default Re: Axle Shaft replacement: Which brand? (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">advanced auto with the lifetime warranty, i paid about $60</TD></TR></TABLE>
X2
After you turn in your core, you get like $40 back. Lifetime warranty is the best
Old 08-07-2007, 05:46 PM
vrrodri's Avatar
yup, I replaced BOTH axles with autozone units and so far no issues, they fit fine.
Old 08-08-2007, 03:37 PM
tj2133's Avatar
Old 08-08-2007, 03:50 PM
gtlaw1's Avatar
no, even if there was with a stock or near stock ex you'll never know the difference
Old 08-08-2007, 03:54 PM
cartune network's Avatar
Default Re: Axle Shaft replacement: Which brand? (gtlaw1)
go with napa or auto zone. but if u want summin thats gonna hold up to alot more hp than stock (i dont know what ur set up is) i would recomend http://www.driveshaftshop.com/item170655.ctlg there alil more expensive but will hold up to the power alot better and they dont mind being launched alot.
Old 08-09-2007, 01:20 AM
CapnKrunch's Avatar
Default Re: Axle Shaft replacement: Which brand? (cartune network)
NAPA, Auto Zone, or Shucks are fine.
kmb562
06-30-2018 02:57 PM
kenzo42
Suspension & Brakes
07-26-2013 05:39 PM
slammedbbs
05-03-2011 08:43 PM
docfletcher
02-21-2011 06:52 PM
deviant1
17
10-20-2003 03:42 AM
Quick Reply: Axle Shaft replacement: Which brand?
