axle question, cant find my answer! DESPERATE!
I cant figure out nor find my answer maybe Im not looking for the right words or wrong search but im desperate for the answer.
Is there a difference in passenger axle between a 90-93 ls block and 94+ls block?
This setup is on my 99-00 civic si, running on lsvtec.
Every axle I tried on for 99-00 civic si is short, on the passenger side and i get shakes, vibration, axle popping out.
Seagull Management
Re: axle question, cant find my answer! DESPERATE!
Driver's side '90 - '93 Integra, '94 - '01 Integra, '94 - '97 Del Sol Vtec and '99 - '00 Civic Si are all the same. Make sure they aren't giving you '86 - '89 Integra axles.
Do you have a 4 door? This is just what a friend said, but 4 doors are supposedly wider. Look up the part numbers for an Integra 4 door and a 2 door. Maybe my friend is right, but definitely check before buying another.
if you are trying an axle for a 99-00 civic and it's not the si model axle it will be wrong.
B series and D series are different you need an axle for a b series tranny/drivetrain.
Seagull Management
Oh crap, in that case '90 - '93 is different than everything else, but can be used if you use the '90 - '93 intermediate shaft and axle seal. you'll know if you have the wrong axle because '90 - '93 passenger side axles have a male end where they go into the intermediate shaft, everything else has a female end.
Nathan_W
10-15-2013 07:17 AM
