View Poll Results: what block and internals??
Multiple Choice Poll. Voters: 41. You may not vote on this poll
awd vtec turbo eg
awd vtec turbo eg
hi everybody
---i am from romania(eastern europe) and i built, as the title says,a awd turbo,based on a '93 civic eg5(d16z6) converted with a b16a2 engine,a crv gear box,and the rest of the transmission from a '91 ee4 civic wagon.
---the car drives awd very smooth,no noises no nothing,but due the lack of a good ecu tuning,i think the spacers betwen the pistonrings are broken,as i get large amount of "boost" from the roker cover....
---anyways i want to buid a pawerplant that could go easy with boost (1-->2bar)and for this i need support,ideas,facts,all parts etc
---i'm after building a b18c stroked to 2.0,low CR(??) everything forged,turbo camshafts, all there's to it.
---othe things i have to finish on the car are:
---the exhaus fom downpipe to the verry end
---going back to rear discs
---buld a nice fuel tank to fit in the original spot,as the car is a sleeper and only if you look under it's ''skirt'' there's somethig unusual.........
thanks
thanks
Re: awd vtec turbo eg
hi everybody
thanks
thanks
--and boost was betwen"""""""
--what should i do to find out if it's not what you said??about the pcv...tke it out??
--another reason ,i read,can be the fact that i used a block guard and never verified the bore,if it sufered deformation.
--the engine is not burning oil...but the blown gases from the valve cover have strong fuel smel
--steel waiting for your opinions,configurations for my powerplant,a part source at rezonable prices,even used if in good condition.
--looking for- b18c sleeved block
-a stoker kit(rotating assembly)to fit in
-valves,springs,reteiners,and camshafts
-good source for basemaps or beter,explains about ecu tuning(maybe a standallone)
well most of us are in the US so were not sure where you would be able to find some of that stuff with out insane shipping costs (parts wise). I know Russia has alot of Grey market hondas straight from japan so if you know any one there you may try them> I do have a question what trailing arms did you use? an how much did you have to shorten them?
--with the russians,no way!!!they speak just theyr oun language,and that is not even related to mine.(romanian is in the latin family),and they are very dangerous people outhere.
--i have a friend in the states who can help me with the shipping,as he knows someone in the romanian comunity,or something.
--i wanted to go for larger dissplacement,but i read that the b20 is'nt boost reliable
--about the trailing arms...i don't remember the messurements, but when i get the chanse to find another pair i will do them better.
--the existing ones on the car are not verry preaty looking after cutting and welding them a few times,but they are stong.
--i tried just one time to make the adapters for rear discs but i failed,and looked on the net for some already made but ...badluck
--i said the spacers,the parts betwen the pistonrings,but not sure as i did'nt disassemled the engine.
And to test the PCV you take it out and shake it, if nothing happens on the inside then its broken. they are like $6.
i need a good base maps source to make one more try before opening the engine.i have to instal properly the catch can with the pcv out,and see if i get the same problem...
anyway i want to buy a b18c block,a stroker kit for that(2.0)camshafts,valvetrain,etc
what numbers???
i need to give one more chanse to this engine,and then to build the new reliable powerplant
for the last try i'm talking about i need some base mapping help
so if you can provide any...you'd be appreciated for the help
cheers
cheers
