Automatic or Manual Steering Rack
My 98 Civic Hatchback that I just bought does not have power steering but has a cylinder attached to the engine where the power steering belt should connect to. It does not have a reservoir. Does this mean my car used to have power steering and therefor has an automatic rack and all I would have to do is get a reservoir and ps pump? or did all civics come with that cylinder and I might have a manual steering rack??
Thanks
Thanks
Re: Automatic or Manual Steering Rack
If the pump is there, you more then likely have a power rack. I wont say forsure becuase who know whats been done with it.
does the lack of PS bug you? If it doesn't remove what's left and leave it.
I forgot to mention it does not have a power steering pump also. Just the cylinder that turns the belt attached to the engine. That is why I am wondering if it ever came with PS.
I've adjusted to no power steering and kind of like it but I've been told a manual rack is a lot easier with the ratios. I also have another civic I am scrapping and I would be able to take the pump, belt and reservoir from it. It would be a lot easier since I do not have to change the rack.
Look at your steering rack and see if it has hydraulic lines leading to it. If so, you have a P/S rack with (what sounds like) no pump. IF not, you have a manual rack already.
The cylinder you are describing sounds like the crankshaft pulley. If the car has A/C then the engine gets the 3-Belt Crank Pulley, but it does not mean that the car has P/S
op, post a pic.
