Power Steering Pump
Power Steering Pump
Looks like all the Si models came with power steering. Can this be removed or is that a bad idea? I dont care for the pump and all that crap.
Re: Power Steering Pump
^^Wrong.
If you remove the belt only (i.e. half *** it), it will be difficult to steer the vehicle since you will be fighting the fluids still in the steering rack.
You must drain the steering rack, loop the lines, and the re-fill while removing the pump and all the other stuff. I have been riding without P/S in my 99 EX for about 2 years with no problems. There are DIY guides on how to this if you search around a bit.
The Grumpiest
Sorry. But everyone seems to disagree from everything else I've read. No one says you cannot ride around like this but the consensus seems to be it still is not the same as having NO power steering from the factory.
Ek Forever y0!
A power rack actually has a tighter ratio. You can remove the pump and just loop the lines. But it's critical you have a breather tube/reservoir for the open lines so the oil has somewhere to go. You don't want to close the system.
A good alternative is getting a power steering pump from an MR2 that is electrical, run it off of the fuse box as a high amp accessory.
Black R
11-08-2012 12:30 PM
BlackEyeRed
10-22-2012 09:12 AM
