automatic to 5 speed swap a few thing
5 speed tranmission
shifter –Done-
shift linkage –Done-
manual ECU
manual starter
flywheel
hydraulic lines –Done-
clutch (pressure plate, disc)
pedal assembly –Done-
clutch master cylinder –Done-
slave cylinder –Done-
shift **** –Done-
shift boot –Done-
miscallaneous nuts and bolts –Done-
all the things that say done, i will be buying from a guy here on honda-tech for a good price, but i know i need to get the 99-00 EX ECU, Im just going to swap a full d16y8 engine with tranny into the car, might as well. But i wanted to know, do i really need a manual starter, or if i buy a full engine swap will it come with the manual starter. The automatic start should still start the car, but i have a Si Cluster, so i don't even see the automatic lights as it is. My firend left his auto LX cluster in his car, he did a auto to b18b 5 speed, in his civic. And he had a shop do it, so he doesn't know if he had a manual starter or not.
shifter –Done-
manual ECU
manual starter
flywheel
shift **** –Done-
shift boot –Done-
Re: automatic to 5 speed swap a few thing (Quad-Damge)
yea u do need the starter from a manual one. i didnt have one when i did mine so i had to drive all the way back to the yard where i got my parts from.
Re: automatic to 5 speed swap a few thing (salbaje)
won't it just able to mount on there using the automatic on, u can always bend it, or just save the time and buy the melt side front mount
Auto to 5 speed swap completed!! Do's and Don'ts! 56K go do an oil change and come back ....... seri
Smith Wise
92
12-07-2015 05:26 AM
stackz
01-07-2007 05:02 PM
CivicHP
19
06-03-2005 07:35 AM
