Auto to Manual in EG Sedan..finished but mount question...
I was wondering if anyone else has done the auto to manual swap in an EG sedan. I have had this swap for close to 2 years, but I recently turbo'd my car, and when I completed the swap, the front lower tranny bracket/mount did not line up, so I left it off. Well, with the turbo, I am getting wheel hop, so I want to find a solution to this problem.
I have a front lower mount, but it is not flat where it meets the transmission, and the transmission has a flat spot where the mount is supposed to fit flush. I was hoping someone else has done this swap. I was wondering which front lower transmission mount I needed, because the one I have (not sure if it's from the automatic or not) will not line up with the holes in the lower "frame rail".
Any insight into this will be appreciated because I really want to get that mount installed.
Re: Auto to Manual in EG Sedan..finished but mount question... (civicseth)
im not sure but one of my friends did the swap and i think there is an auto to manual mount made for the auto to manual swap...again i may be mistaken but im pretty sure there is a mount for it....n e way good luck
I'm not talking about the main upper mount. I know about that. I have the Hasport mount for that. I'm referring to the front lower "torque" mount.
Re: (civicseth)
i sent you an instant message but if you didnt get it. you will need a manual mount. they're completely different.
i'll go snap pics so you can compare.
Re: (Slow Eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow Eg8 »</TD></TR><TR><TD CLASS="quote">i sent you an instant message but if you didnt get it. you will need a manual mount. they're completely different.
i'll go snap pics so you can compare.</TD></TR></TABLE>
Awesome, that'd be great. I think I might have the manual mount. Hopefully I do. For some reason I was thinking we tried it but it wasn't lining up correctly. I'll have to check again.
turboblack2door
06-08-2011 02:50 PM
getnasty
11-17-2005 12:56 PM
