ARP head stud problems
Old Oct 16, 2002 | 06:54 PM
98civicEX's Avatar
Default ARP head stud problems
well, short block is kicking and ready to go. start putting in studs....all studs in...get head and place it on....the studs are 1" + too long.....WTF? application is d16y8 block and head. the part # on box is right. I took out the studs and compared to the stock...it's still 1"+ too long (working on getting pics up) i thought they migh of been B-sereis..but i looked at the spcifications and B-series said 11mm...i know these are 10mm....any ideas?
[Modified by 98civicEX, 7:55 PM 10/16/2002]
Old Oct 16, 2002 | 07:10 PM
mntdewred's Avatar
Default Re: ARP head stud problems (98civicEX)
you're not the first person to have problems with d16y8 arp studs...i'm reluctant to even look at mine
guy i talked to said an ARP worker said they don't work with Y8 motor and he had to return his...i don't know man, hopefully someone can clarify this.
Old Oct 16, 2002 | 07:14 PM
98civicEX's Avatar
Default Re: ARP head stud problems (mntdewred)
this pisses me off, then they need to clarify and say D16z6 only!!! or whatever specific applications they fit.
Old Oct 16, 2002 | 07:30 PM
D-Man's Avatar
I think you might have the wrong studs if all 8 are that longer,i can see 2 being to long like what happened to me,i got an extra D kit at work,ill measure the length of mine when i get in tomorrow morning,with my D16Z block with D16Y head.only the two outer rear ones needed a couple of extra washers under them to make em fit.
Old Oct 17, 2002 | 06:24 AM
D-Man's Avatar
ok.at work,those D studs of mine are 6 7/16",just under six and a half inches.
Old Oct 17, 2002 | 06:27 AM
98civicEX's Avatar
Default Re: ARP head stud problems (D-Man)
thanks for the info...i'm going to check mine once i get home
Old Oct 18, 2002 | 06:45 PM
D-Man's Avatar
anytime...let us know how you make out?
Old Oct 18, 2002 | 08:48 PM
mntdewred's Avatar
I measured mine as well and got the same as D-man, 6 7/16"
92_civic_eg
Engine Machining & Assembly
Aug 27, 2016 07:24 AM
JDMCRX
Jul 22, 2013 05:04 PM
sundownz
Feb 17, 2007 08:27 AM
ATS*Mark
Jan 23, 2004 04:08 AM
