anyone know how to reset SRS?
Re: anyone know how to reset SRS? (hawjboi)
you can't....you can pull codes the same way that you do check engine codes...but to my knowledge, you need to have the dealer reset the circuit.
I've even tried switching ecu's
Re: anyone know how to reset SRS? (SuperDragII)
you can reset it, ya unplug the grey and grey 2 pin yellow harness goin into the front of the fusebox, connect a jumper to the plugs turn the key on (II) the light will go off after 6 secs when that happens remove the jumper. The light will then come on again, when it does that reconnect the jumper. The light then goes off again and remove the jumper right away when that happens. The light then blinks which means its been erased.
Zuul
07-15-2005 08:13 PM
