Anyone have a link for this swap?
Ok so I've searched on google and even searched the forums. Haven't found much of anything on a b20b 99-00spec into a 95 eg cx. All I know is its the same ole B series swap; you need mounts, shift linkage and a different intake mani. But what about the wiring harness and what not? I know you use an ls ecu. Do I have to get an obd2 wiring harness? and which one will go into a cx? Sorry if this question(s) have been asked before. Also if anyone knows a link that would be great. Thanks.
Re: Anyone have a link for this swap?
well finally found something. Here is a link for those who had similar questions.
http://hondaswap.com/swap-articles/5...20-tech-29112/
Use the search feature, it's at the top of your page, this topic has been covered a million times. But for the record you need 94-01 integra axles, half shaft, and shift linkage. You can use stock mounts if you want to, you use your stock civic harness, and you need to get a obd1 distributor and fuel injectors. You need to use a LS intake manifold. You can use a obd1 p75, p74, or pr4, but it will run lean. To properly make it run you need Hondata, with a B20 basemap, but you can use a fuel pressure regulator and bump the fuel pressure up, but it still won't be as strong as a Hondata tuned car.
diycx
09-13-2003 04:11 PM
