Any EG guys have this cluster in there car?
http://cgi.ebay.com/ebaymotors...22731
looks sweet but can i get it to work?
Re: Any EG guys have this cluster in there car? (Ryan C)
sorry that's the best i can do right now...i could get a better picture but that's time consuming. everything works perfect!!! only thing is that the fitment is a bit off. I still have yet to trim the edges and put on an EG cluster cover. Other than that, I love my Teg cluster.
Here's the wiring....
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
match the color wire and function from the intregra harness to the civic harness..
Re: Any EG guys have this cluster in there car? (shermanyang)
sweet...thanks man that is wicked helpful.
as far as the fitment goes...it bolts right in but the edges are off a little?
Re: Any EG guys have this cluster in there car? (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">$45 is cheap. It'll probably go for about $200+.</TD></TR></TABLE>
umm, no...i'm pretty sure $50 is the going rate on these
http://search-completed.ebay.c...om=R6
I recently bought a 2000 integra cluster (20000 miles) for $60. I am planning on doing the same swap into my EG. Make sure that wiring diagram is for the right cluster because I heard their are some differences from 94-95 and 96-01.
Take a look at this thread real quick.
https://honda-tech.com/zerothread?id=353305
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">i always thought obd1/2a/2b clusters had different wiring... anyways 180kph speedo = </TD></TR></TABLE>
Not really, one or two wires may differ but most are mainly the same. I have a 00' USDM GSR cluster and only like 2 wires were off. I can't remember which ones were off though.
Also, I decided to get the USDM cluster cause it goes all the way to 150mph...not 180kph which is just around 110mph
BubLBack
12
09-07-2006 09:23 PM
msinsky14
12
03-01-2006 07:36 PM
92cxgsr
03-14-2002 06:34 AM
