Another question on gettin rid of rust in engine bay...
Old 04-15-2007, 01:28 PM
rleonekc's Avatar
Default Another question on gettin rid of rust in engine bay...
Ok i posted about this not too long ago, on solutions on how to get rid of this..
Well today, I was cleaning my engine/bay, and i noticed that the rust is very light, and not that bad at all, so i started rubbing it, and i got most of it out...So what i was thinking is, should I just sand it down, primer it, and paint it?
Also, is it supposed to be painted red? Obviously the car has been in an accident...
Shoot me your opinions...
Also, can I just use auto spray paint and primer you can buy in a can?
Old 04-15-2007, 01:42 PM
rleonekc's Avatar
Default Re: Another question on gettin rid of rust in engine bay... (rleonekc)
bump
Old 04-15-2007, 01:48 PM
dem0nk1d's Avatar
i would sand blast it out... or use a paint stripper, and clean it down to bare metal. then poor some muriatic acid on it... muriatic acid you can npickup at homedepot in the pool section.
Old 04-15-2007, 01:50 PM
rleonekc's Avatar
Default Re: (dem0nk1d)
ok sounds good, but when i go about painting it do i primer the whole thing then?
and is the original color supposed to be the same as the car? or black>?
Old 04-15-2007, 01:55 PM
dem0nk1d's Avatar
primer, sealer, and then paint. the sealer prevents water from going back into the metal. causing rust.
Old 04-15-2007, 01:56 PM
rleonekc's Avatar
alright thank ya
Old 04-15-2007, 01:57 PM
dem0nk1d's Avatar
what ever method you'll use, you should pull everything out so it doesn't get damaged.. also for your application, you must just want to use a paint stripper that you can get at any autoparts store or homedepot . Also use a wirewheel in a drill and clean it that way.
1.8EG-T
Paint and Body
12-22-2014 09:52 PM
creed86
Paint and Body
18
09-19-2012 10:48 PM
v8~killa
Paint and Body
02-24-2008 10:54 AM
crxpwr1
20
06-09-2006 07:27 PM
boomslang
11
10-07-2002 11:22 AM
Quick Reply: Another question on gettin rid of rust in engine bay...
