analyze this
analyze this
I went to track for my first time and it was so fun. on first run, i ran like mid 17. I was so nervous. I was expected low or mid 15 but i couldn't break 16. here's my 2 best times. someone tell me what am i doing wrong. b/w i got 95 del sol si with i/h/e and pretty much stock.
R/T....0.995.....1.280
60.....2.601.....2.547
330...7.016.....6.942
1/8....10.617...10.584
MPH...68.31.....67.60
1000..13.714...13.715
1/4.....16.326...16.352
MHP....84.19.....83.41
is it my driving? or is it normal?
Re: analyze this (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote">What kind of tires are you running? Did you release and air pressure when you made the passes?</TD></TR></TABLE>
It's real cheap tires. it says cooper cobra and it came with the car when i bought it from a old man. what do you mean releasing air pressure? tire air pressure?
I saw some people pulling low, mid 15's with d16. how do they do that?
Unceasing Measure
Those 60 foot times are terrible, but they scream "stock tires at stock air pressure" . Decent tires and/or lowering tire pressure to 15ish should shave some off . Not bad for a D16, don't get discouraged.
Re: (bearboy80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 »</TD></TR><TR><TD CLASS="quote">how can i improve 60ft time and R/T?</TD></TR></TABLE>
r/t time has no effect on your overall times. you may loose against your opponent but thats all.
lower the tire pressure and use stickier tires. what wheel/tire setup and pressure are you running???
defitanly mid 15 sec car
Re: (bearboy80)
R/T can be improved by leaving on the last yellow instead of the green (depending on the type of tree )
60' could be improved, like the others said, by lowering your tires' air pressure (I go between 15-20 psi or so) and by launching differently ie. higher RPM, different throttle application.
Re: (NightHawk)
so do i deflate front tires only or all 4 tires?
so R/T does not add upto my final time? I didn't know that.
Modified by bearboy80 at 4:07 AM 9/1/2003
Risky Business
Re: (bearboy80)
2.5 60ft is total horseshit...
deflate your front tires to 20psi, and launch from around 5,000 and see where that gets you...if your 60ft times are around 2.2 or 2.1 thats where you should be
xDelSolSiR
16
03-03-2008 08:36 PM
explosive
07-17-2003 10:18 AM
