are all the brake lines for del sol, civic, integra interchangeable?
as the title listed.... does anyone know? thanks
my del sol have 4 wheel disc, thanks!!
1 Post
Re: (HuffRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HuffRacer »</TD></TR><TR><TD CLASS="quote">I need some help! Can the rear disc brakes off an 91 integra fit on a del sol and what do i need to run the lines?</TD></TR></TABLE>
don't thread jack!yes,the 91 Teg rear discs will fit.get the whole setup including e-brake cables and brake lines and you'll be fine.
to the original poster-do you mean front or rear?i can say 99% for sure that they are the same.of course,rear drum lines won't work with the rear disc.
Chris
Chris
Re: (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
thx chris; i think i read somewhere about the Integra uses a larger brake line nut which the del sol doesn't and need to mod it a little bit, thanks again!!
Re: (gakkuken)
Okay lets get this 100% straight. Yes the lines will work. Now, I guarantee they will 'fit' differently. Some lines will have more slack than others. And having to much slack will cause propblems. You run the risk of the lines catching something, ie. wheel(s), axles, basically any moving part in that area. What I suggest you do is have custom Stainless steel lines made. I just had mine made about a week ago and it only cost me about $60 for 2.
TSPeed Factory
Re: (SOHC4life 96)
i'm running full front and rear gsr brakes on my del sol and used the gsr brake lines. the lines were the same, from what i can remember. only difference is you'll have to use del sol si or VTEC e-brake cables for the rear disc brakes.
mugen_sol
07-29-2015 10:57 AM
Kod Sol
06-21-2006 07:27 AM
seanc520
02-16-2006 01:26 AM
fc3srx729
07-03-2003 07:31 AM
