air fuel meter hook up
Re: air fuel meter hook up (sohcvtec1995)
some say the O2 wire off the header bung, others say At the ECU, I need to fix mine cause it just lights up bout 10 blocks and rocks back and forth... I let cousin install it!
Re: air fuel meter hook up (civiksiracer1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiksiracer1 »</TD></TR><TR><TD CLASS="quote">some say the O2 wire off the header bung, others say At the ECU, I need to fix mine cause it just lights up bout 10 blocks and rocks back and forth... I let cousin install it! </TD></TR></TABLE>
Pretty much any A/F meter setup on a stock o2 sensor is a light show. If you want a real A/F setup you need a wideband, stock o2 sensors are just too flaky.
Re: air fuel meter hook up (NOSpeed97)
did that it, and it did not work. This is my friends car, and i just did it like i did mine, but he only has one wire. And would he have the fat white wire on his ecu? I think he has a P06 ecu.
Re: air fuel meter hook up (aw1234dude)
Thanks for the help. And i dont think the gauge is just a light show, its called engine monitering. Then you get a Vafc/Safc and tune your fuel map.
2fast4uguys
14
04-28-2005 06:08 AM
tyflip2
06-11-2004 06:18 PM
