air/fuel guage hookup in 2000si
Old 10-03-2006, 02:17 PM
99delsol's Avatar
Default air/fuel guage hookup in 2000si
ive searched and found nothing,can somebody tell me where on the ecu can i hook up my a wire air/fuel guage,what wire is it and on what plug.if you know please give me some help thanks i have a auto meter guage red,black,purple
Old 10-03-2006, 03:47 PM
xNOBOOSTx's Avatar
im am unsure where to hook it into the ecu, but everyone that i know that has installed one has wired it to the o2 sensor. but they never throw accurate readings unless you have a wideband. more less just a light show. and the purple wire is the one you will need to hook up.
Old 10-03-2006, 06:16 PM
99delsol's Avatar
do i hook it up to the one on my downpipe or my exhuast o2 senser.thanks
Old 10-03-2006, 06:26 PM
-Intl Steve Krew
Caoboy's Avatar
for a more accurate reading...source the o2 wire on the ecu. and yeah, no point in really having it, unless you have a wideband, which you would be running a separate o2 sensor for it anyways.
Old 10-03-2006, 06:43 PM
xNOBOOSTx's Avatar
if you do decide to wire it up on the factory o2 sensor wire it on the primary one.
Old 10-03-2006, 08:00 PM
Slammed_am's Avatar
Default Re: air/fuel guage hookup in 2000si (99delsol)
isn't it just going to bounce around eratically and only really work at WOT off a stock o2 sensor?
Old 10-03-2006, 08:12 PM
xNOBOOSTx's Avatar
yeah pretty much. that is wh ymany people say its just a light show. some think it will tell you if something is seriously wrong but i dont believe it. but some people like having the sweeping lights in there face all the time while driving.
Old 10-03-2006, 08:34 PM
99delsol's Avatar
i know its a light show but i already have the guage ,then why not use it ,anyone know what wire on the ecu i hook it up to?
Old 10-03-2006, 08:40 PM
Bond's Avatar
Default Re: air/fuel guage hookup in 2000si (Slammed_am)
um well sort of actually. if you ever have tested ur o2 sensor with a multimeter you would know what it would kinda look like. basically a cold o2 goes from .5-9volts i believe. been awhile since i have tested one (prolly a couple of months) it will do this when it's in closed loop and will do this at a very rapid rate. once it's warm the volt's should hold a steady reading at idle and go up as the rev's rise. stock o2 is a very limited way of reading your a/f and i would suggest money is well spent on a wideband as it will help if you ever go N/A build or FI.
just remember closed loop is by taking preset values for a/f and not sending back a signal. once it's open the o2 and ecu communicate and adjust the a/f as needed.
TylerH
04-07-2006 02:18 PM
gsr30035hatch
03-01-2006 05:59 PM
FusionITR
02-28-2002 11:50 PM
Quick Reply: air/fuel guage hookup in 2000si
