Adjustable shifter for 00 Civic??
quick question guys. For a 2000 civic, is there such a thing as an adjustable shifter which lets you position the shifter wherever you want. im not talking about the actual shifting mechanism aka short shifter. What i want to do is be able to change the position of my **** close to the drivers side, but dual bend shifters do not really allow for adjustability. Something i can raise or lower, bend or rotate at my convinience. i know it sounds crazy but there has to be something like this out there
Also, can i just change the shifter without tapping into the gear box or do i need to mess with the whole linkage assembly regardless if it s just the top shifter part i want to change... thanks
Re: Adjustable shifter for 00 Civic??
I know B&M makes adjustable shifter for drifting... Im not sure it its available for our model cars though. If you were to thread a piecd of pipe to fit the top of your shifter though you could make one yourself... Ive seen it done. Search around.
Just curious why do you want an adjustable shifter?
I lied. Pacesetter made them.
http://www.pacesetterexhaust.com/quikshift.htm
Also is there a "shifter" thread i can look for the positions these so called shifters give.
And lastly, will i have to do the entire process of switching out the linkage or is it just a bolt on? thanks
JDM_rolex
01-01-2014 07:16 PM
stehigs321
12
10-03-2007 09:39 AM
