ACT 6-puck disc questions??
New User
my clutch is slipping pretty bad. i decided to go with 6 puck from ACT, i tried taking out the tranny the other day and ran into a problem. well i took off that big bolt that is located in the middle of the lug nuts. but what i cant remove is that axles. i was wondering if anyone has any instructions on replacing this clutch. please help. thanks guys.
Re: ACT 6-puck disc questions?? (hatch_react)
Removing the axle to pull the tranny really isn't that bad. All you need to do is remove the spindle nut like you have, then unbolt your spring shock assembly from the front lca, and the upper suspension from the chassis so it can fold down, this way you have more room to work. Next you just have to work the axle out, it'll take a little wrestling but it should come fairly easy. Once you have the axle out the rest is a piece of cake.
Brian
Brian
O16581724 5 2 5
13
09-22-2005 11:39 PM
ActiveAero
01-01-2003 10:34 AM
