AC problem. Need help. Its hot in paradise.
My ac compressor is surging.
Clutch goes on off on off repetitively. Like a surge.
It blows cold but is drawing power from the motor.
When i first start it its fine. Then i rev and hold it at 2000 rpm.
Then on off on off on off on off.
I checked all the relays and fuses. They are all good.
The low pressure is fine. Cant check the high pressure.
Its a 1996 civic coupe.
Re: AC problem. Need help. Its hot in paradise.
a/c blowing will "drain" some power from your motor, and as long as its not feeling like its going to stall out while driving i think you are ok. you could always see if a new/different compressor helps. yours may or may not be on its way out.
autozone ftw for stuff like this
edit: nvm still expensive as **** from autozone
I don't think you can avoid the power draw but the compressor surging could mean your system needs a charge.
As for autozone we dont have one.
Checkers
napa
redline
cw carter
hawaii imports
pacific jobbers
or the dealer which i never go to.
Yeah it is nice but then it starts to rain. Then the windows fog up. And if i use the heater it gets worse only the ac helps prevent the windows from fogging.
Mine use to do the same thing. I added some oil to seal the unit and then put in some freon. It was frigid cold. If it doesn't last, you could need o-rings or have a slow leak.
Check the condenser fan, I had a similar problem with AC clutch bouncing around. The fan should be on when the AC is on.
Could it be that it has too much pressure?
Or the reciever dryer is clogged? I noticed a sensor on it and when i disconnect it the clutch goes off.
JesseCRX
23
08-11-2008 04:40 PM
