ABS 94ex /94gsr brake options
I have a 94 ej1 with 4wheel disc 4wheel abs. (These are the exact same size as gsr front and rear found out the hard way after shelling out the dough for the swap)
and I have had problems with the abs not working or working too much and wanted to know if anyone has had simalar problems an if so what advice you had. The whole suspension was swapped including springs and now has an ls motor. I have been running this setup for 3 0r 4 years and have always had problems with brakes. I now have sbs rotors and pads all the way around and while it stops a lot better it seems to lock the rears now instead of activating the abs which used to be hyper active. any thoughts. I drive in the mountains a lot and can' live without the slotted rottors they allways used to fade really bad. With the new rotors I havent been able to make them quit yet.
