ABS help
Old Dec 17, 2001 | 08:34 AM
Teggyb18b's Avatar
Default ABS help
With ABS on the back brakes can you still pull up the ebrake and lock the tires up cause my car doesnt do it it just slows the tires down slow.
Old Dec 17, 2001 | 09:03 AM
VTechie's Avatar
Default Re: ABS help (Teggyb18b)
#1) You shouldn't be doing this anyway.
#2) The emergency brake is unrelated to ABS.
#3) The wheels aren't locking because the braking force is insufficient to break traction.
Old Dec 17, 2001 | 09:37 AM
Teggyb18b's Avatar
Default Re: ABS help (VTechie)
OK #1)i like to have fun
#2)i think the ABS is
#3)what do you mean?
Old Dec 17, 2001 | 10:40 AM
Teggyb18b's Avatar
ttt
Old Dec 17, 2001 | 04:05 PM
ingrate's Avatar
25 Year Member
2.) i think it isn't.. ABS has nothing to do with your e-brake...
Old Dec 17, 2001 | 04:24 PM
Teggyb18b's Avatar
Default Re: ABS help (KooKaT91)
I have ABS on my LS integra
Old Dec 17, 2001 | 06:17 PM
MrFatBooty's Avatar
The parking brake does not actuate the hydraulic calipers that clamp on your rear rotors. It uses a cable to lock the inside of your rear hubs.
The ABS is not connected to the parking brake. You probably have simply worn the parking brake out of adjustment trying to do handbrake turns in an FWD car.
Old Dec 17, 2001 | 06:18 PM
Tomakit's Avatar
Default Re: ABS help (MrFatBooty)
you've either worn the brake out, or have weak arms.
Tom
Old Dec 18, 2001 | 12:07 PM
Teggyb18b's Avatar
see KooKaT91 knows what im talking about having fun but mine dont work i think it is loose is there any way to tighten it
Old Dec 18, 2001 | 12:29 PM
MrFatBooty's Avatar
He's talking about his '67 Baja Bug. Look in his signature.
Old Dec 18, 2001 | 02:49 PM
ILOVEGIRLS's Avatar
u can adjust ur e barke cable..its under the arm rest area. so that means u have to take off the arm rest to gain access. whats so fun about pulling the e brake?
hondaboy4life
Dec 28, 2007 09:48 AM
XES
Oct 19, 2005 08:14 PM
cambopheonix56
Jul 17, 2005 09:04 PM
tossnupweight
Dec 26, 2004 03:43 PM
