99 em1/ls turbo - swap in a n/a motor?
Old 10-20-2012, 07:20 PM
decon's Avatar
Default 99 em1/ls turbo - swap in a n/a motor?
Hey guys i have an 99 em1 with an ls turbo swaped in-place of the b16. But lately i have been thinking of going back to an n/a motor. So was wondering what would be the best way to go on a motor. I was thinking of just going back to the b16 and adding a few mods to that. or would i be better off getting a better motor?
Old 10-20-2012, 07:21 PM
been there done that
doood's Avatar
Default Re: advice on em1
so you want to be slower?
Old 10-20-2012, 07:49 PM
decon's Avatar
Default Re: 99 em1/ls turbo - swap in a n/a motor?
right now im mostly wanting to have a car better for daily driving, and being in texas having no a/c sucks. But what ever i do im looking to make 200whpish. Car is making 230 whp on the turbo, so wouldnt be that much of a drop.
Old 10-20-2012, 07:55 PM
Bystrov's Avatar
Drive down to FL and ill swap my EM1's B16 with your LS
Old 10-20-2012, 08:06 PM
C_Rock77's Avatar
Why not get an AC compatible manifold?
Old 10-21-2012, 05:12 AM
decon's Avatar
I though about it, just when im looking at fitment, i can see room for the compressor but not room for the condenser.
Heres a pic of the engine bay to show what i mean.
Old 10-21-2012, 01:49 PM
dookie_j's Avatar
what part of texas are you from?
Old 10-21-2012, 02:03 PM
jestin91's Avatar
put a gsr with b16 head and type r cams (poormans type r)
Old 10-21-2012, 02:46 PM
RT_NEWYORK's Avatar
What type of horsepower would that build make roughly ?
Old 10-21-2012, 04:23 PM
The Grumpiest
grumblemarc's Avatar
Old 12-20-2012, 02:36 PM
Hypnotise305's Avatar
Im in Texas, I have a em1 k24a2 and I still dont use AC. I just roll the windows down and enjoy the breeze. Temp in Texas is easily any where from 30 to 70ish degrees. I honestly would keep the LS Turbo. You will miss it once it is gone I promise.
If you still want to get rid of the LS Turbo I know some people that would be interested.
P.S. Im located @Ft Hood
Old 12-20-2012, 02:39 PM
Man U FTW
Schister66's Avatar
AC compatible manifold....
/thread
Old 12-20-2012, 03:00 PM
jbpnoman's Avatar
In this case, it's not the manifold that's the problem, it's the turbo. I have the same manifold style on what is basically a modified T25, and it fits just fine. That looks like it might be a GT60. The snail is probably WAY too big for the engine, and is obviously too big for the engine bay.
Old 12-20-2012, 06:14 PM
Retired Moderator
EsotericImage's Avatar
if he pointed the inlet the opposite direction, you would have room for AC.
you only have a cheap ebay manifold anyways, so either way ~ replace the manifold or turn the turbo around and POOF! A/C compatible!
and also you can mount your rad and your reservoir the correct way when you swap
Old 12-20-2012, 06:18 PM
jbpnoman's Avatar
He'll also either need to get a new dump tube fabbed, or run without it.
Old 12-20-2012, 06:20 PM
Retired Moderator
and downpipe will need re-fabbed.. still alot cheaper then swapping in another engine.
Old 12-20-2012, 06:25 PM
jbpnoman's Avatar
Also, even flipping the compressor side won't solve the problem. It looks like the exhaust side of the turbo is too big. Like I said, looks like a GT60. Way too big for that motor.
Old 12-20-2012, 07:29 PM
decon's Avatar
na its a precision t3/t4. But I said screw it and haven't done anything. But yes the rad and the over flow are mounted like crap. Just haven't cared to mount them to look correct.
Old 12-20-2012, 07:33 PM
Retired Moderator
t3/t4 doesnt tell us what size the turbo is.
a 50/57 trim will fit on pass side with a little shaving.
either way, its doable and alot cheaper then switching out the whole engine
Old 12-21-2012, 12:28 PM
decon's Avatar
its a 57 trim, totally forgot to add that in.
Old 12-24-2012, 05:08 AM
kyden's Avatar
uh.. no. it looks like your ordinary run of the mill t3/t4 combo.
DEATHB4DlSHONOR
03-04-2010 06:51 PM
skcivic4life
20
09-26-2007 05:42 AM
boostedeghatch
05-06-2005 04:54 AM
crackerjacker006
11-22-2004 11:34 AM
deceit
05-24-2002 09:57 AM
Quick Reply: 99 em1/ls turbo - swap in a n/a motor?
