99-00 front on 97 EK ??
Old 03-21-2012, 02:14 PM
SOURjD's Avatar
Default 99-00 front on 97 EK ??
My hatch was recently stolen and recovered and im now in the process of rebuilding!! It acquired some front end damage from the tow truck picking it up and dumping it in the towyard with no wheels on it!! I have all the parts for the conversion but i need to also replace the damaged radiator support and dont know if i should stick with the 96-98 support or if i should go with the 99-00 support if possible. Will the 99-00 bolt up to my 97 frame??
Old 03-21-2012, 02:26 PM
JDM_teh_WIN!!'s Avatar
Default Re: 99-00 front on 97 EK ??
Yeah it'll work.
Old 03-21-2012, 02:34 PM
SOURjD's Avatar
Originally Posted by JDM_teh_WIN!!
Yeah it'll work.
Thanks, hopefully its as easy as i got the answer to that ??
But do you know why the part #s are different?? or why they just dont keep it uniform from 96-00??
Old 03-21-2012, 02:47 PM
Because the 99-00 are different from the 96-98. Usually when people do the 99-00 to 96-98 conversion they end up having to modify where the bumper mounts to the radiator support. So if you are doing the 99-00 conversion you wont have to worry about modifying it.
If you look at the individual parts for a 96-98 or 99-00 the only part numbers that are different are the headlight parts. Thats where the bumper mounts to.
Old 03-21-2012, 02:54 PM
Gabe624's Avatar
I used my 96-98 radiator support, I just had to drill 2 holes, the mounting for the bumper cover is different. If you're already buying the radiator support, you may as well buy the 99. Everything should bolt right up without any modification.
Old 03-21-2012, 04:09 PM
Master Detailer
98civdx's Avatar
get which coresupport you can find cheapest, either will work.
Old 03-22-2012, 08:45 AM
SOURjD's Avatar
That's exactly my reason for asking!! I found a deal on a 99-00.
Thanks for all input!
Old 03-27-2012, 04:11 PM
takata00's Avatar
if you found a good deal on the 99-00 i would go with it IMO
Old 03-27-2012, 04:23 PM
KoNEY's Avatar
NO!
Old 03-27-2012, 06:27 PM
ej8hybrid's Avatar
it will bolt right up you jus gota either tuck the bumper or nitch out a piece off the radiator support so the tabs will slide in on the bumper cover
Old 03-27-2012, 06:38 PM
KoNEY's Avatar
OOOHHH!!!! Yea, I forgot, you gotta use that special spotweld socket to remove the spotweld bolts. So silly of me!
Old 03-29-2012, 12:44 PM
TriniSpeC's Avatar
Theres a particular drill bit to drill out spotwelds. Its not really cheap, easier to have a bodyshop handle it if your replacing the core support, but its not necessary.
Old 03-29-2012, 01:10 PM
rtimeteg's Avatar
get you back started 2000 front bumper and fenders 150$ no grille HMU and also rear bumper with lip
JLEK
01-10-2007 05:44 PM
stuie08
06-07-2006 10:13 PM
95ejjj
39
10-04-2005 06:26 PM
GetSmoked
11-14-2004 10:57 PM
s2000june
13
10-10-2004 11:23 AM
Quick Reply: 99-00 front on 97 EK ??
