98 jdm b16a shuts off while driving?
hey guys noob here on to this but I been having trouble with my jdm b16a shutting of while driving on freeway. it just started happening like a coupe days ago and I don't know what it could be any ideas what it could be nee some help its really annoying me
Re: 98 jdm b16a shuts off while driving?
could be the ignition switch.
There was as recall on this for 96-00 civics. So check into that, call honda and ask them about it and give them the vin.
If its not that then it could be the main relay.
Does it start right back up?
When. I was driving on the freeway I would feel like it turn off then back on quick then after it would compete turn off once it turned off I took the key off then back on started it back on normal but it did hesitate to start back up a bit when idling it sounds fine
sounds mire like the ignition switch.
the main relay causes problems when hot. so it nornally takes a min or 5 before it will start back up.
check this and see
http://owners.honda.com/service-maintenance/recalls
but from what i know is ignition switch, main relay, and battery cables.
everything else would make it cut off at idle from being so rough.
thecorey
05-09-2023 08:24 PM
