98 GSR front suspension/brake swap..
I have a 93 CX hatch. I just got a complete front suspension, sway bar, upper/lower CA, and the front calipers and would like to ask if I should mount the GSR sway bar at the same time. The car has no rear sway bar at the moment. Will it be a bad handler in terms or understeer? I am upgrading to the GSR factory brakes to give me some better stopping power up front. I will also install a Skunk2 upper control arm when I install the front suspension.
Another question : Will the stock civic brake lines install right on or should I get Teg brake lines? I have to bleed the brakes anyway. I am installing Maff front rotors and Rofren pads. Thanks,
[Modified by hybridcivic93cx, 4:39 PM 4/21/2002]
Re: 98 GSR front suspension/brake swap.. (hybridcivic93cx)
try a search. I gaurantee you will find your answer.
but yes, it will fit, search for the details
Re: 98 GSR front suspension/brake swap.. (tonyxcom)
Will the front sway bar alone cause a dangerous handling situation, the car has no rear bar. Thanks,
ScottF
09-17-2012 04:15 PM
project_mercy
12-16-2002 08:42 PM
