98 EX 02 Sensor Wire info???
98 Civic Ex Auto V-tec
I need to know the wire info on the o2 sensors, both of them
Theres 4 wires.. 2 blk, 1 white & 1 green
What is the white wire for? (sensor or the Heater wire?)
whats the green for? (sensor or the Heater wire?)
I know the 2 blacks are ground, sensor and heater ground.
I just picked up a brand new o2 sensor BUT I i have to cut and reconnect to the honda harness, thats why I'm asking the wire info...
Let me know
Thanks
Let me know
Thanks
Re: 98 EX 02 Sensor Wire info??? (iMPoRT GeeK)
the new 02 that i got had 4 wires too
1 Black
1 Gray
2 White
how do i match up with the stock 02 harness wires, where its 2 blk, 1 white, 1 green.. ???
ANyone?
Thanks
1 Black
1 Gray
2 White
ANyone?
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iMPoRT GeeK »</TD></TR><TR><TD CLASS="quote">I know the 2 blacks are ground, sensor and heater ground.</TD></TR></TABLE>
You were given incorrect info then.
White = signal
Green = signal ground
Black 1 = +12v, switched
Black 2 = controlled ground from ECU
Don't know about your other O2....but aftermarket O2's seem to make OBD2 ECU's unhappy. I'd stick with OEM.
White = signal
Re: 98 EX 02 Sensor Wire info??? (EE_Chris)
Yeah my wires came outta my plug and i had to plug em back in and i plugged the wires in wrong any help with which wires go where just match and play? or whatnot
genocide43110
12-12-2006 02:09 PM
