please help!!!!!! manual steering rack conversion problems
converting my 98 ex to manual steering rack, got manual rack from 96 dx universal joint on my steering is too big teeth do not grab ordered joint for 96 dx from honda still too big. does anyone know what the problem is????? and how to fix it.
Re: please help!!!!!! manual steering rack conversion problems (fkncivic)
Why not just leave the 17:1 power rack in and loop the fluid line instead of swapping in a 19:1 manual?
Re: please help!!!!!! manual steering rack conversion problems (Spade)
well my ps pump went bad and i wanted to get rid of the extra weight so i already got rid of all the lines and stuff. sooo if anyone has some ideas they would be very much appreciated.
I ran into the same problem on my 99 Si. Bought a 97 DX rack and discovered that the coupler (both stock and a 97 DX)was to big to grab the rack pinion shaft.
I called up hondaautomotiveparts.com and they discovered that there were actually 2 different part numbers.
The following part number worked for me ( it fit the steering column on a 99 Si and the shaft on the manual rack):
53323-SR0-003
53323-SR0-003
Re: please help!!!!!! manual steering rack conversion problems (NXSpoon)
hey thanks man, looks like im going to be hitting up honda tomorrow morning
I just wanted to confirm that NXSpoon was correct regarding the linkage.
Just performed a power steering to manual swap yesterday on my 2000 Civic Si. Purchased a manual rack from detroit axle and the steering linkage part #53323-SR0-003 from www.hondapartsnow.com
Swap went great with minimal modification.
Will be writing an article on this swap on honda tech in the future to help anyone that was in my position with what seems like no other resources on the internet for this job.
all_motorsi
04-06-2007 11:25 PM
tthame1
06-21-2004 01:50 PM
fabshybrid
06-02-2004 04:19 AM
hatchiedave
15
04-30-2004 04:55 PM
