98 cx y7 2 y8
Old 11-01-2007, 05:25 PM
spoonfedjdm's Avatar
Default 98 cx y7 2 y8
ok i got a 98 hatch cx with a 1.6 y7 non vtec, i got a y8 itm what all do i do?
Old 11-01-2007, 05:34 PM
Default Re: 98 cx y7 2 y8 (spoonfedjdm)
bump
Old 11-01-2007, 06:12 PM
-JSpecEk*9-'s Avatar
Old 11-01-2007, 06:16 PM
ejoner's Avatar
Default Re: 98 cx y7 2 y8 (-JSpecEk*9-)
What exactly are you asking?
Old 11-01-2007, 06:19 PM
Default Re: 98 cx y7 2 y8 (ejoner)
to put the itm on, like do i got to do any wireing or mod anything.
Old 11-01-2007, 06:26 PM
97Ej6mike's Avatar
Theres actually a few things that need to be addressed.
First of which, the IACv.
Unless the Y8 your putting in the car is auto, it will have a 2-wire IACv when your car's harness will have a 3-plug one. Can either re-pin it out yourself, or just get the Y8 harness along with it.
The y8 also has VTEC, so your stock harness for a y7 will not have that, again, needs to either be wired by hand, or get the y8 wiring harness.
What ECU do you plan to use? If you plan on using a p2p (stock y8), it reads for a differnet EVAP system than any 96-00 DX/CX/LX comes equipped with, therefore throwing a Check engine light, as well as compromising your car's ability to pass state inspection (depends on area) This can be solved by either obtaining the correct charocol canister (honda dealer or junk yard) from any 96-00 civic EX. Tis would be a pain to pin out by hand, again, i highly suggest just obtaining the Y8 wiring harness if you plan on staying OBD2 and emissions legal.
-or-
run a p28 and a jumper if you dont want to run into some of those issues.
Old 11-01-2007, 06:32 PM
jbfw's Avatar
https://honda-tech.com/zerothread?id=735196
Sticky's are nice...
Old 11-01-2007, 06:34 PM
Z3120's Avatar
If your ITM is from a Y8 auto, just remove and replace. If your ITM is from a Y8 Manual you must plug up the IACV holes before installing. Then Plug up the cruise control vacuum port/nipple. Make sure you check all gaskets/o-ring and replace as needed. You will need a Y8 intake arm and air box also.
Old 11-02-2007, 10:25 PM
Default Re: (Z3120)
thanks
Preluda1992
08-11-2018 12:05 AM
98EJ7Y8
11-15-2011 05:10 PM
SOLEpassion
03-10-2010 04:26 PM
boomnn
03-28-2008 04:22 PM
joker4096
03-17-2007 06:57 AM
Quick Reply: 98 cx y7 2 y8
