98 Civic HX - running rough and TDC code :(
Old 06-25-2012, 12:08 PM
EGGman94B18's Avatar
Default 98 Civic HX - running rough and TDC code :(
I've got a 98 Civic HX, completely stock. Just got the car a couple months ago. It has 245,000 miles on it and the car ran fine when I test drove it so I bought it and it drove fine for about a week. Then the check engine came on and it acted as if it wanted to die, cutting in and out, while I was accelerating. I ran the codes and it was throwing a TDC sensor, so I replaced the dizzy and the problem wasn't fixed. It's now at a shop. I was going to have them do a y8 swap, but they wanted a lot and I don't have that kind of money. So I asked if they could fix what was wrong with that motor, told them the symptoms, and they told me they'd get back with me. After about a week I called them back and they said it was throwing a misfire code, (which they apparently fixed with new plug wires) along with some others, basically telling me my manifold was garbage. I know a replacement for an HX is really pricey so I just asked if they'd be able to put a used y8 one on for me and call it a day, and they are currently checking pricing and availability. I'm not sure what to do from here but I am considering picking the car up tomorrow and doing things myself. Any advice or what you guys think could be wrong?
Old 06-25-2012, 12:09 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 98 Civic HX problems :(
So what is the issue right now?
Old 06-25-2012, 12:17 PM
It's still running like crap, cutting out and what not. The manifold is cracked. I was going to have them y8 swap it, but it was 2,400 bucks because apparently they're so different and changes to all the wiring and stuff. They want $700 for a new manifold, so I asked if they could put a used y8 one on there and put a cat on the actual exhaust, and the shop made excuses of why they couldn't do that. How similar are the D16Y8 and the D16Y5? And would I be able to put a y8 mani/header on my y5?
Old 06-25-2012, 01:31 PM
Former User's Avatar
You brought the car in with a TDC code. Is that fixed?
If you have tools and are willing and able to learn, get you car out of the shop and fix it yourself with our help. I see no reason at this point to be talking about engine swaps. The great gas mileage of the HX can return your investment.
Old 06-26-2012, 02:05 PM
As of right now, that's the plan. I'm picking the car up early tomorrow and going to start digging into it myself. And the TDC code was fixed, but the check engine came back on 2 days after I replaced the distributer and it threw that code again. I guess I just got a bad distributer. Then the shop said it was throwing a random misfire code (the plug wires fixed) and then an EGR code. They said nothing about the TDC
Old 06-26-2012, 02:15 PM
The TDC code obviously was not fixed. A bad TDC sensor in the distributor is only one possible cause for the code.
When you get the car home, pull the codes. Then reset the ECU and see which codes repeat after running the engine. Post codes that repeat.
Old 06-27-2012, 10:03 PM
I'll do it tomorrow, and probably a compression check to be on the safe side for the misfire. I'll post results as soon as I get them
Old 06-28-2012, 05:03 AM
Originally Posted by EGGman94B18
...and probably a compression check to be on the safe side for the misfire
Given that you have an HX, I'd recommend that you inspect the EGR valve and EGR chamber on the intake manifold for clogging prior to doing a compression test.
Rick1t
03-30-2015 11:46 AM
S!K TEG
32
07-27-2014 04:33 PM
Brandon04GT
03-09-2013 05:01 PM
mauroe
06-01-2011 11:38 AM
Burnt Toast
05-06-2008 06:55 AM
Quick Reply: 98 Civic HX - running rough and TDC code :(
