98 civic hx rear o2 sensor
Old 06-02-2009, 01:29 PM
n8dizzel's Avatar
Default 98 civic hx rear o2 sensor
im wiring up a 98 hx rear o2 sensor and i got a bosch 15733 universal replacement but the colors don't match. i know this is the correct one. the stock sensor is 2 black wires 1 white and 1 green. the bosch is 1 black 1 grey and 2 whites. please help!
Old 06-03-2009, 03:31 AM
b16_sol_707's Avatar
Default Re: 98 civic hx rear o2 sensor
hondas don't like the bosch sensors. I would return it and get the right one.
Old 06-03-2009, 08:15 AM
Master Detailer
98civdx's Avatar
i had one in mine and threw a code the second i started it.
put a ngk in problem solved.
Old 06-03-2009, 08:16 AM
civic_driver's Avatar
I bought the same universal Bosch O2 sensor a while back for my EG and the sensor didn't work properly. I still had a CEL after I replaced it. So then I changed it with an OEM one and the CEL went away.
Old 06-03-2009, 08:45 AM
Former User's Avatar
Check post #19 at this thread. You might want to buy the OEM sensor:
Downstream sensor (M/T & A/T) OE Type - Bosch 13249.....$81.89
Old 06-09-2009, 10:34 PM
n8dizzel's Avatar
I figured it out. both the Bosch whites goto both the black wires. then just followed the rest of the pattern. Bosch black to civic white and Bosch gray to civic green. code is gone everything is all good. really if u just hold both the sensors upright and match the whites to the blacks. you just gotta finish the pattern. if you have the stock civic plug and the Bosch manual in front of you. its takes a second to get it but really its just process of elimination and once you got two wires done, its a no brainer. i don't think there is anything wrong with the Bosch sensors. just people wire them up wrong or there is another problem causing the CEL in the first place.
1997civichx
Engine Management and Tuning
12-30-2014 01:37 PM
mommyslittlegreaser
10
01-23-2008 06:29 PM
notguilty411
05-27-2005 08:56 PM
CilVirCurfer
08-08-2004 11:10 AM
Quick Reply: 98 civic hx rear o2 sensor
