98 civic fuel pump toggle
Re: 98 civic fuel pump toggle
i checked the relay and its good .. jumped the pump and car started right up .. but when i use the key to try the pump its a no go .. could it be i need the obd2 to obd1 jumper harness ?? or something else
i dont plan on bypassing .. never thought of it once... and i have a mini-me d16y7 with a d16y8 head, harness and all y8 sensors .. i am running a p2p ecu .. currently waiting on a obd1 chipped ecu .. the relay is good the pump is good .. just cant seem to get power to the pump .. i checked the fuse in the box next to the pedals but everything seems to be good .. i thought it was the ecu at first but was told from many of different people that it wouldnt be the ecu no matter what .. but the ecu is where im at now
thanks ronj@ht .. and on the other hand .. how hard would it be to put a toggle switch with a fuse in the correct way ?? really dont plan on doing this but just wondering if its a possibility if this is the way i have to go
thanks again ronj@ht
so far youve provided me with the best answers and they are understandable also
and thats not the case at all cause i got spark just cant get the pump to power with the key .. when the pump is jumped with a 12v power source .. the car runs
I had same issue. Have you checked the check engine light codes? Is the cel solid or does it blink a solid cel indactes bad ecu,also checking for proper voltage at map when key is on run postion is a easy way to check if ecu is good should be 5 volts if there is not yor ecu is bad. Mine had 2.4 volts
