98 b18b1 into 98 ek
98 b18b1 into 98 ek
ive searched but im still finding mixed questions/answers in need to get this swap done asap. plus i still havnt found a person to swap it in.
couple questions maybe its already been answered numerous times on this forum if it has then im blind i guess. well here it goes.
98 b18b1 motor.. i know couple mounts can be reused. but i do need some si mounts .. as far as axles .. 94-up integra or si's will work. and also obd2 ecu.
anyways thats all i know. so heres my questions..
what the hell do i need haha to complete this swap??
will stock 98 civic throttle cable work?
will existing harness work??
so far. i have the motor/tranny starter..alt..ecu..shiftlinkage..
im tellin you people.. if you guys have the extra crap i need im willing to buy it from you asap haha just to make it easier. but i do need help blah
Re: 98 b18b1 into 98 ek (b00stedLS)
you need the rear tranny bracket ....and the front lower vibration bracket and a/c bracket you need from any b series swap. the wire harness will work only you're going to be missing the knock sensor. if you have a dx then you'll be missing the vtec pressure and vtec solenoid from the engine wireharness. axles you can use from any b series 94-up integra or si....good luck
is that ls going into a ek hatch? or coupe, well either way ull like the tq on it haha, the rear si brakets are cheap u should go to pit crew in san gabriel i got it from them for 20 bucks i think, u dont need vtec wires unless ur going lsvtec, if u need someone to help u swap it my friend does it for really cheap, compare to shops
u could use the stock harness just need certain plugs from the ls one, well thats what im using now, but with the single cam ecu runs like **** but still beats b16as
how about throttle cable.. can the existing one be used or does it need to be replaced by one from an LS. if so.. does the years on which LS matter? thanks for the great help so far
Cjs_slowkey_ej6
08-21-2015 06:59 AM
716pro
03-10-2008 08:33 PM
