97 load sputer
Old 04-11-2014, 08:36 AM
rex pwr's Avatar
Default 97 load sputer
I rock a stock 97 civic for a daily right now tell I get my new motor done for it but that won't be ready tell late summer right now it has a D16y7 and not all the time but every once and a while under load it will have a what feels like a misfire and I was wondering if anyone had any ideas I put new plugs, cap, rotter, and wirers with nothing changed I come to you for help any ideas?
Old 04-11-2014, 04:31 PM
rex pwr's Avatar
Default Re: 97 load sputer
Bump really want to figure this out
Old 04-11-2014, 04:33 PM
The Grumpiest
grumblemarc's Avatar
Timing. Check it.
And it "feels" like a misfire? It either is misfiring or it isn't. Does it throw any codes?
Old 04-11-2014, 05:54 PM
rex pwr's Avatar
No code and I just checked into the timing looks fine can a random misfire come from the distributor?
Old 04-11-2014, 06:06 PM
95accordCE6's Avatar
Check the coil for any carbon tracks or cracking, check the harness for any corroded or broken pins going into the coil, then start with other basics like the fuel filter. Intermittent problems are generally electrical though, but always check the simple things first so you don't jump into expensive parts and labor only to find it was a $20 part. I wish I could help more but good luck
Old 04-11-2014, 06:12 PM
I never narc'd on nobody!
NotARaCist's Avatar
You say it "looks" fine. Did you use a timing light? Is it within spec? It's either in spec, or it isn't.
Old 04-16-2014, 05:49 PM
rex pwr's Avatar
It is within spec and I have yet to look into the coil
eldudepapi
04-22-2017 03:16 PM
ek_ct
08-24-2015 03:58 PM
SpadedEK
12-23-2009 08:57 AM
grnhatch94
10-12-2009 01:53 AM
jesse d
06-18-2006 07:03 PM
Quick Reply: 97 load sputer
