97 Civic - Blower motor intermittently works (solved)
Old 05-25-2016, 02:01 PM
NcDurk's Avatar
Default 97 Civic - Blower motor intermittently works (solved)
This is my first post, just looking for a answer to a problem I've been dealing with.
The car is 97 Civic EK b20 swap.
I have a issue with the blower motor.. Sometimes it'll work fine but then times I'll have to hit the bottom of the blower motor for it to kick on. Note: there are no debris in the fan, fan spins freely.
Fan works fine after I hit it, atleast for a little while anyways. Then ill have to hit it again. Just wondering what else to check. Fuses are good.
Old 05-25-2016, 02:24 PM
Former User's Avatar
Default re: 97 Civic - Blower motor intermittently works (solved)
Replace the blower.
Old 05-25-2016, 04:34 PM
NcDurk's Avatar
Originally Posted by RonJ
Replace the blower.
Thanks I will try the blower motor.
Old 05-25-2016, 07:34 PM
oneheadlight's Avatar
I got a new blower (fan+motor) for my 96 civic. Was like $30 from rockauto, the brand is TYC. You can find it at other places too, price should be around the same. The TYC one actually puts out more air than the old one. The factory one wasn't that strong to begin with. Just to let ya know there are some affordable quality options out there
Old 05-25-2016, 08:00 PM
NcDurk's Avatar
Thanks!! Appreciate the help guys.
Old 05-25-2016, 08:02 PM
hey you're welcome! that's what we do 'round here, share good knowledge!
Old 05-26-2016, 07:50 PM
fcm
Old Fart
fcm's Avatar
Because blower resister is mounted to the blower box it may also be the problem, so if replacing the blower motor does not solve the problem, the resistor is the next thing you would replace.
Or you could bypass, the resistor, [supply a direct ground to the blower motor] and if that does not solve the problem, then replace the blower, if it does solve the problem, replace the resistor. 94
Old 05-27-2016, 08:58 PM
NcDurk's Avatar
Thanks for the tip. Will try the bypass tomorrow afternoon. Appreciate the help!
Old 05-27-2016, 09:18 PM
Blower speed 4 bypasses all three resistors, so if the problem occurs even at speed 4, the resistors are ruled out.
The fact that whacking the motor makes it work is consistent with bad motor brushes.
Old 05-28-2016, 05:34 AM
NcDurk's Avatar
Once again I appreciate all the help guys I've pulled the resistor it looks mechanically fine. The problem occurs on all speeds 1-4. Will replace blower motor first.
Old 05-28-2016, 07:51 AM
mk378's Avatar
Measure the voltage across the motor when the key is on, switch is on, but it is not running. If you have voltage but the motor does not turn, it must be bad.
Intermittent operation is very typical for a brush-type DC motor with the brushes worn out.
Old 05-28-2016, 07:58 AM
Unfortunately, the blower motors in our Civics are sealed. To replace the brushes, you effectively must destroy the motor.
Old 05-28-2016, 07:10 PM
NcDurk's Avatar
Fixed: Replaced blower motor everything is working fine now. Thanks guys.
Old 05-28-2016, 09:22 PM
good news!! but I gotta ask.. what brand of blower motor did you buy?
Old 05-29-2016, 05:48 PM
NcDurk's Avatar
Had a buddy of mine with a OEM replacement laying around so I bought it off of him. Not really sure what brand honestly.
Old 05-30-2016, 04:17 PM
tamboo's Avatar
Default Re: 97 Civic - Blower motor intermittently works (solved)
4 seasons makes a good blower motor.
mine's over 10 years old and still going strong.
rockauto has them with or without the fan.
David Berger
Honda Civic (2001 - 2005)
08-04-2017 11:59 AM
EgHatchy96
06-26-2014 12:31 AM
Ninjatek
08-07-2010 04:49 PM
092eg6
08-08-2009 10:30 AM
MrBurns71
09-15-2006 07:08 PM
Quick Reply: 97 Civic - Blower motor intermittently works (solved)
